Help mkiii not starting
Streettyrant
12
El Paso
I drove and started it this morning and part of the afternoon I wasn't driving it hard just normal. Now the car won't start it turns over normally but won't actually start any suggestion. Something I might be overlooking I'm looking through it right now haven't found anything obvious. Thanks
Next time it does it try jiggling the cps wire by the connector and see if it starts.
Rafagazos
Virginia
What he said^^ I had a similar problem mine would crank but wouldn't start unless i moved the cps or jiggled the wires going to it. Re-did the wiring and timed it correctly and problem went away
Streettyrant
12
El Paso
I'm not sure if its goin to be in the same location tho because I bought this car with a 1jzgte swap but ill check it out thanks
Have you checked for spark or fuel?
Fuel pump come on?
Ecu getting power or has it been repaired at all?
Streettyrant
12
El Paso
ok so i pulled a spark plug and it sparks so would that rule out the igniter? and what would be that best way to check the fuel system without dropping the fuel tank?
