Help have no spark
fjing60
15
Houston
Hey i have a 87 that has no spark. I let it sit two weeks since the last time it ran. Ecu is good. Has new coil, cap, rotor, plugs, wires. I think its my ignitor but I want yalls take. Ive only had it running for a month. It would die spontaneously and wouldn't start for awhile. The problem was a bad connection between the ignitor and coil so I put dielectric grease in the plug. Any info will help!
jenny89
96
andersonville tn
Sounds like the igniter is the only thing left. there's no procedure to check on non turbo models but if u have checked everything else its a good chance that's ur problem
8,871
The distributor has a CPS in it. You could say the pick up in both vehicles is the same, less the secondary igntion on the 7MGE.
