Does anyone know who to "flip" the MAP axis values on the VE table? I'm trying to get 00Kpa low on the table and 320Kpa to the top. I went in the XDF and edited the header appropriately, customized my "VE Table Custom MAP Axis", using excel I flipped the table and copy'd it over. Tracing is correct going from the top/left of the table, down to the bottom/left.
But I look at the VE sig on the monitor and it still thinks its on the original axis taking data from the old cell location which is now at ~90VE with the MAP axis correct and the tracing bubble correct showing its should be ~55VE.
If I don't edit the xdf header and change the custom MAP axis table then only the user tune VE table changes. If I make the appropriate changes in the user tune VE table with the MAP axis changed, it only changes the same CELL location on the VE table not the correct MAP/RPM location.
I've searched around and ~98% of all VE tables I see posted are orientated how I would like it, 00 Kpa low and 320 Kpa high. What am I doing wrong here? I though I had everything covered but obviously I forgot something, I'm going to feel stupid when someone tells me the answer because its probably something simple. Thanks
Edit: Turbo Dave helped me out and as I thought it is something simple. After I put everything back that I had changed, all I had to do was click the "reverse rows" Box in Tools\Preferences\General. Thanks again Dave!
