Ok i just installed my TT with PnP harness and seem to be having some problems. When I plug in the TT with the car off my battery light and wideband will turn on(my power wire of my wideband is wired to the ecu). Also when i turn the car on to test the TT and then turn it off the TT will just sit on the time and not countdown and the car will never turn off unless i disconnect the whole unit.
What is going on, is the timer itself toast or is there an issue I'm over looking, and yes the e-brake wire is secure.
