hey there i am buying a used engine from the scrapyard and sending it to advance engine rebuilding in woodbridge, they got the most warranty per kms, just want to know if there is anything i need to add extra to the engine
the engine is for a swap going into a pickup
and goals are more power and more mpg
400hp at the crank tops
not sure if performance valves and after market pistons will help the mpg
the crank will be machined and balanced
any extra sensors needed ? ect ect?
do you think copper head gaskets is that important when the heads are machined?
any problems with the 7mgte? as of internal that needs to be dealt with while on the rebuild table, oil and water pump, squirter's ??
thanks
thanks
