i need to confirm these specs as i found them over the internet, help would be appreciated
- head bolts = 25 ft lbs mark ft of bolt and go another 90 x 2, 180 degrees total
- connecting rod caps= 22 ft lbs mark and go another 90 degrees
- main bearing caps= 33ft lbs then mark bolt and go 90 degrees farther
- cam bearing caps= 14,ft lbs in three passes
- inner timing belt cover= 78 in lbs
- cam gear bolts = 59 ft lbs
- valve cover bolts = 74 in lbs
- inner intake manifold 7 bolts =20 ft lbs
- fuel inlet pipe= 30 ft lbs
- exhaust manifolds 29 ft lbs
- turbos= 40 ft lbs
- rear main seal plate 6 bolts = 52 in lbs
- upper oil pan #1 oil pan 22 bolts/12mm bolts= 15 ftlbs,14mm bolts= 29 ft lbs
- turbo outlet pipe 2 nuts= 20 ft lbs
- oil pan baffel plate 5 bolts,2 nuts= 78 in lbs
- oil pickup = 78 in lbs
- #2 oil pan lower pan 16 bolts 2 nuts= 78 in lbs
- oil pump 9 bolts 15 ft lbs
- inner water pump housing= 15 ft lbs
- water pump 15 ft lbs
- flywheel M/T 8 bolts 36 ft lbs then mark bolt and go another 90 degrees
- flywheel A/T 8 bolts 61 ft lbs
- turbos= 40 ft lbs
