First time on the dyno
mkiii 4 life
130
South Florida
It was my first time and i am somewhat disapointed with my numbers but the car was having boost issues.I have an intake, Turbo back 3" exhaust with highflow cat, and a mbc set at 9 psi. The boost would spike to 9 then drop to 6 at higher rpm's :3d_frown:. Im not sure if its my mbc or a boost leak but i will be investigating it this week. Well here are the numbers (sorry i couldn't get a clear picture of the on the dyno sheet so i will type everything out)
1st run:Max Power = 208.6(hp)@5050(RPM), Max torque=237.0(ft.lbs)@4250(RPM)
2nd run:Max Power = 204.9(hp)@5100(RPM), Max torque=248.1(ft.lbs)@3950(RPM)
3rd run:Max Power = 202.5(hp)@4950(RPM), Max torque=236.0(ft.lbs)@4150(RPM)
Here is a crappy cell phone pic just to show the graph:
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Not bad at all man. You know what , I could never get my MBC to hold boost. It could be something as small as a boost leak or wastegate not working properly. Good number man, find that problem and take it to the dyno again...
mkiii 4 life
130
South Florida
Thanks. yea it has been doing it for a while now. I didn't plan on dynoing the car that day, i just went to watch but then ended up wanting to know what i would make so i did it. I will try to fix the issue this week
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Just dont give up on your car man, its got power. All it needs its a lil work . Check out the kills section . 1st day with car running and im already killin domestics AAAAAAwwwhhhh the beauty of it :evil2: good luck
