Guess i should be a little clearer
I have 2 problems,
1. Engine will not rev above 4000
2. Once engine is hot it will not start (it will not turn over like batt is dead, once cooler starts right up).
When I extended my harness, the diagrams I used showed only 1 wire on 1h1 pin 10 B-W, there is in fact another wire B-L which should connect to STA on the ECU. I used my 7M engine harness and left my body harness untouched ie put B1 on the end of the 1JZ engine harness... The B-L wire may not be connected to B1 pin 10 which goes to STA on the ECU.
Just wondering if it is a waste of time or a likely fix to my issues..
Thanks Gents.
