I was hoping to get some clarification on the concept of a bypass filter. It seems I can't find any distinct information determining if it is the filter or the head unit that determines the flow through the second (or first) filter.
I'm planning a system very similair to what Jdub setup in [ http://www.supramania.com/forums/sh...ostat-Controlled-Oil-Cooler-amp-Remote-Filter ] for my 5VZ-FE 4Runner. It uses the same oil filter as the 7M, so the Canton #22-595 is ideal because of the stupid spot the stock filter is located.
I want to use a WIX filter for the full flow filter and a T3/4-20S Trasko as the bypass... does the Trasko's housing handle the flow metering to it's own filter media? Or will using a standard "dual mount" result in having two effective full-flow filters in parallel?
Apparently the BMK23 unit from Amsoil handles the flow metering in the filter head? Does the Permacool Dual Filter Head #1221 do the same?
Long story short is that if the Trasko filter can run as both a full-flow and a by-pass, are the dual filter mount units (from perma-cool and amsoil, for instance) designed to handle the flow change between the two filter types? If they're not, what mechanism would prevent oil from piling into both filters at full flow rates?
And lastly, is the Trasko all it's cracked up to be? They're showing clean oil at +5000 miles? Wow.
Thanks in advance for any guidance you guys can provide.
