Damm camber bolt
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
Hello guys
Kind of in a bit of a sticky situation. The rear camber bolt what's the specs on it? I'm installing the rear camber battle version arms and the tech said he has to cut the bolt off but they don't have any replacements. Is this something I can get at home Depot. I don't need eccentrics anymore cuz of the adjustable arms.
gats
Rebuilding... Slowly!
Mar 3, 2009
182
Sydney, NSW
You will still need the eccentric bolts to provide fine adjustment for the arms to get a decent alignment.
#48190-14010
Ya you want to make the arms he same length as stock and then adjust with the camber bolts. If adjustment is still not where you want it then use the arm for adjustment.
