Hello all,
I cam across these today and though that I should share. What I've found is that you can get ksport coilover replacement springs for about $30 each. if you visit this website you will see that you can select an appropriate spring rate and overall length of the spring. I'm planing to at some point get springs and custom valved bilstiens so I'm hoping these may work. Anyways I thought someone else might want to see these too.
http://endurancemotorsports.net/ksport/ksport_universal_springs/g-52474.aspx
DISCLAIMER!!
I just found these on the web today I'm not saying that these will work on a supra. I'm sure because these are pretty compact springs you would at very minimum need a new perch and who knows how much more work to get them to fit. just saying a spring is a spring and these are cheep if they'll work for your setup.
DISCLAIMER!!
