THANK YOU!! Thats what I was looking for. I have read the difference in the cranks with the Balance, Redline #'s etc., and the limitations / pros and cons of both. So now i guess we'll be looking for a good used crank that doesn't need machining.
I guess the reman cranks from Autozone or Oreilly's are regrinds with oversize bearing eh? Would the reason to stay away from machined cranks at say .010-.020 have ground most of the hardness out of the journals?????
What if any other reason would be to stay away from Crank Kits? Seems to me that finding a Used crank will most likely need machining as well..... Going now to pull a motor and check it out. But I wanted some answers before I go hunting.
A little about me so you guys can get to know me...I am not new to cars at all. I am in my 40's, Have built many engines, Toyota SR5,22R's, Triumphs TR7's, MG's, Volvo 740 Turbo, 855R <----My daily driver, various other Nissan, Datsun, LUV, Buick V6, GM V8's etc over the years. Never have ran into such particulars as this 7M-GTE. I can bring alot of Electronic knowledge to this forum having sharpened my teeth owning a TR7 waaaay back in the day. Some of you guys weren't even born then. Anyway,
Paint and Autobody is my other specialty. Once we get over this Engine rebuild for my son, I want to design an LED Tail Light System and Light Show with a code driven microcontroller and will share my design here... Its not rocket science once you learn the particulars. The hardest part is writing the program to do what you want it to do. But, I will share what I know as this is the place to do so. Supraforums.com.....I have to shake my head..everytime I try to post it says I don't have permission. Sobeit...I have been a member there for almost a year now and still can't post...WTF... Ok...Going wrench spinning. I will post some pics and start a Build thread this weekend.
thanks for the Info.
-=BM
