Cooling System Rehaul
Apollonius
105
Houston, TX
Did this about a year back.
A full rehaul of my cooling system:
PWR Radiator
B&M motor oil and transmission cooler
Dual electric fans on a temp switch
Mocal oil thermostat
Filter relocation with a dual mount for motor oil and single mount for transmission
Trasko micro filter
Total cost was 2000 range, did have some extra AN fittings I got a refund for. None of this is cheap but really wanted to make sure cooling would not be an issue for my car.
Block Modifications:
New oil squiters
New oil pump with Arizona performance oil line replacement and shimmed
272 BC Cams
ARP Hardware throughout
Metal Headgasket
Did have a question on what oil to use with this system. The plan is to go back to redline 5w30 but would like some input on this.
Most of the parts
Lines from transmission
Bit worried about this ones proximity to the down pipe. Did have down pipe ceramic coated any ideas if heat will cuase an issue on the line?
B&M Coolers
Block adapter
Dual fans
Mocal Thermostat
Some pics of the routing, ill try to get some more
8,871
Did you switch to the Canton piece yet for the block adapter? It goes down and is higher quality, much like the rest of your set up.
Apollonius
105
Houston, TX
Higher quality, How so?
I have had no issues with the perma-cool adapter, did have to use two 90 degree bends though.
The funcitonality of the canton is definantly worth a second look but unless it flows better I do not see a point in the change over.
8,871
Flow isn't the issue. The permacool can break, but that doesn't mean it will. And the intercooler hose runs in the same spot. If you are factory original hoses, you can just push them to the side. But that isn't optimal.
Apollonius
105
Houston, TX
I have aftermarket ceramic coated hard pipes and did not have a clearance issue with the perma cool. Went ahead and ordered the other because it does look better built and have a bit more clearance there wont hurt anything.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
It might be wise to add a heat-shielding sleeve to the transmission lines running by the downpipe. The DP tends to get pretty damn hot. At the least, it will add unnecessary heat to the transmission fluid. At the worst, it will melt the polymer in the braided lines.
Ya i would make some sort of heat shield for the trans lines.
I second on the canton pieces. I was going to use a permacool filter adapters but decieded to just pony up and get the nice billet pieces. Those for sure wont break and the filter adapter for the block is nice cause you can turn it any way you want.
That stuff adds up quick but its nice once you got it,
Do you have pics of how you mounted your coolers?
And did you delete ac?
