checking base timing with AEM EMS.
8T7supra
78
New York
can you still check the base time the way tsrm says with the jumper wire when you have AEM EMS or is their a different way it has to be done?
toyotanos
What will we break today?
2,841
Coon Rapids, MN
Nope. Go into ecu setup and choose "Set ignition timing/sync"
Select 'lock timing' and choose an advance setting that you like (0*/10* normal) then press enter.
Connect your timing light and use the AEM advance/retard buttons to change the timing.
Note: It is recommended to NOT adjust the CPS to set timing. Set it to the middle of adjustment and lock it down for good. Not sure why, but I don't really care so long as the car runs well.
Funkycheeze
Grease Monkey
Jul 3, 2009
163
Calgary
Adjusting the CPS is usually done with the AEM to get rid of any 'stumbles'. I found it works best if they are set to full retard (HAH!), and then use the AEM set timing sync thingy to get the static timing correct.
