car dies out sometimes and sometimes it wont start :(
peste noire
266
los angeles,CA
so recently had this problem. car died while i was making a u turn and wouldnt turn on. gave it 5 min and it turned on drove fine the next day, till i parked got some food and came back and it wouldnt start. thought maybe it could be the cps so i changed it, since i had a spare. and it turned on so i went to park it and next day it wouldnt turn on tried to start it for like a minute then i eventually got it on and went around the block and it died again but started right up.
any ideas what it can be?
i think it has something to do with spark cause when i crank it and it doesnt wanna start, the rpm's dont move as it cranks.
maybe the coil pack??
i have no codes . any help is really apreciated.
jonahs_supra
1,015
Lancaster, Ohio, United States
just as razoe stated
i would let it run and start jiggling wires
focus mainly on cps, tps, coil packs, afm and iscv wires and plugs
also check your ecu grounds arent loose...located on lower side of upper intake manifold
next time is stalls check to make sure you have fuel and spark
peste noire
266
los angeles,CA
razoe: decided to check the cps wires again(even though i had them fixed not to nlong ago) and yup one was loose. so fix it right a way and no more dying. thanks guys.
