Can i get your opinion
jdub
Feb 10, 2006
10,730
Valley of the Sun
Royal Purple XPR Racing oils are not suitable for a street car. It does not have the additives necessary to keep the oil viable for street conditions. Just because something says "race" in it's label does not make it good ;)
Suggest you research this section and come up with a different oil.
airhead04
1,489
Lima, Ohio, United States
Im going with 5w30 for right now. Mobil1 5w30. Not the best, but not the worst.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
For the money you're spending for the (Group III) Mobile 1, you'd be better off getting Pennzoil Platinum if you're gonna run a Group III based synthetic.
RiyadYar
384
NY
i recommend you read jdubs oil 101 class in his signature its very informative
jdub
Feb 10, 2006
10,730
Valley of the Sun
Poodles;1419429 said:
jdub: thought you might be interested in this about RP: http://www.bobistheoilguy.com/forum...n=113354&Words=purple&Search=true#Post1568288
Seems to break down to a lower weight quickly...
RP is notorious for doing that. From that analysis, it does look like the additive pack has improved though...I see RP is still using a stout amount of ZDDP (zinc) in their formulation. Helps explain the low wear numbers even though the oil sheared down to 20W viscosity.
