Cam Timming
Spec-DMK3
D-Spec
Jun 27, 2008
Saskatchewan
so if i wanted to retard mt timming i'd turn my cps counter clockwise this would free up a few extra hp in the higher rpm?? even with my factory cams??
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
The CPS adjusts spark timing, not cam timing. To adjust cam timing, you'd need adjustable cam gears. Set spark timing to stock specs per TSRM, unless you have a standalone, then you can set it to whatever you feel like since you have complete timing control.
Spec-DMK3
D-Spec
Jun 27, 2008
Saskatchewan
if i were to advance my ign. timming a few degrees it will free up a little more power?? i'm at 10psi how much would you advance it at this point..?
