Ok so im getting ready to start ordering parts to build a bottom end for my DD supra. Heres the parts list.
New oil pump
New clevite .010" rod bearings (for crank machining due to spun rod bearing)
new je pistons .020" over (not standard size)
new eagle rods
arp rod bolts and arp main studs
gasket set
Am i missing anything for the bottom end?
A machine shop will be assembling / balancing / blueprinting the motor, and is there anything i need to tell them tolerance wise? Im running a stock head right now with a HKS mhg and ARP studs.
Im trying to build it right the first time and not have to do it again.
Thanks Supramania
New oil pump
new eagle rods
gasket set
Thanks Supramania
