My IPT built A340E performs best with ATF temps at the lower ends of that range...180 deg F. Up shift into overdrive and converter lock-up (< 37 MPH) is inhibited when coolant temps are under 140 deg F.
Vehicle load is what produces heat for an auto tranny...my cooler is a Long's TruCool rated at 24,500 GVW (8"x11"x1 1/2"). IPT recommended this cooler, but any stacked plate cooler in this size range should be adequate. B&M makes one with an attached fan switched at 160 degs...excellent choice if you have to position the cooler in a location without direct air flow.
If I turn in the converter for one with a higher stall, it will heat up more. 24,500 is a pretty big size. And after getting the stacked oil cooler from B&M, I will be doing the same on the trans cooler. If IPT says that is needed, then that is good enough for me.
