Hey guys i have an 87 mk3. 2 weeks ago i lost braking power, did some tests and ruled out that my brake booster was bad.
I ended up replacing both the brake booster and brake master cylinder, when everything was put back together and ready to be bled, I gave the pedal a couple pumps and I could hear air when pressing on the pedal. I had a buddy pump the brakes while I listen and look for leaks and found one between the master cylinder and booster. I thought maybe I got a defective master cylinder so I got it replaced.
Got the new replacement installed and I'm still having the same problem!
Have any of you guys ever had this problem or maybe someone can point me in the right direction on how to solve this?
