Blue smoke in between shifts
87MK3Turbo7m
Boost-My Anti-Drug
Mar 7, 2007
9
New York
hi i have a 1987 supra 68,000 miles and when i start giving it some gas and spool up the turbo when i shift a little cloud of smoke comes out like a grayish blue but not while im driving.. also when im reving it up only enough: were the turbo spools when its reving down it thows out a little smoke i just wanna see if it is the turbo and not the rings.. :1zhelp::1zhelp:
Boostedstr8six
I have better SA than you
Near Columbia, the river
If you often have to add oil between changes and don't have an oil leak then it very well could be bum rings. If you don't have to give it oil too much but still have visible oil smoke during normal operating temps then I would strongly suspect the oil seal on your turbine (hot side of the turbo). It usually fails with excessive shaft play and/or old age.
Boostedstr8six
MDCmotorsports;918698 said:
^Good man. Problem is, you just can't replace the seal. The whole turbo has to be rebuilt.
Very true. Replacing just the seal would be like placing a 'band aid' on a 3rd degree welding burn to the forearm. If you love your turbo, send it to MDC. I mean it! ;)
now, back to our regularly scheduled troubleshooting session...
AllStreet
51
Michigan
Form what sounds like it is your turbo, this is what you do. Turn your car on for exactly 1 minute, has to be cooled then started for 1 minute, get the Rpm's to about 2500, then turn off the car take the turbo off you should see oil on the hot side, I had a '90 Supra turbo with 155,000 and my ct-26 started going out, I thought it was my engine, saved a lot of time figuring out ti was the turbo. Good luck man!
_________________
"Supras owners let Supras drive them "
88YotaTurbo
658
Wolcott, Ct.
same thing was happening to me. I replaced the turbo and and all was well. But i'm not saying your problem is the turbo.... I checked shaft play first and it was horrendous. +2 check shaft play
