Best Diff Gears for 7mgte/r154 for 1/4mile????
DGmk3
DomesticMan sucks
May 15, 2006
122
Superior WI/(Duluth MN)
I'm currently running the stock 3.90's at about 400hp...I have a set of 4.30's in my garage..By spring I SHOULD crack 500hp and plan on going to the track..should I stick with my gearing or swap in my 4.30's..this isn't my DD so gas mileage and hiway rpm's don't matter...I'm just sketchy about the gears cause I burn through 1st in a flash as it is..
DGmk3
DomesticMan sucks
May 15, 2006
122
supradan22 said:
You will spin more but those gears are better for the quater mile it may be time to invest in some slicks.
I know I wish I had more $$$ to get some nice rubber for the back I get beat by civics in 1st gear
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
To be honest, I don't really like the 4.30's with a larger turbo. Not enough load in 1st and 2nd gear.
Tun_x
Built to do the NASTY!!
Utah
I was wondering about gears and where I will be at as far as where i will be at mph wise
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
4.30's + 1/4 mile + stickies + 500rwhp = well...just hope you can drive. ;)
As long as you can handle ripping through the gears so quickly and have some GOOD slicks, 4.30's are VERY beneficial.
Jeff
drjonez
the motor city
www.4cefed.com
Jeff
bingo. the idea behind gearing is to choose the highest numerical ratio to allow for the least amount of shifts in the 1/4. in 99% of those here, that means a 4.30. this, of course, assume good traction- i.e. slix.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
I had 4:30's in my old supra and it was a blast... but you will go through 1st-3rd very quickly...
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
oldschool85 said:
stick with 3.73's. with the 4.3 you will be bouncing off the rev limiter right when you cross the finish line.
That completely depends on your setup. Saying that with the 4.3 you will be bouncing off the rev limiter is a statement that is only true if...
Like I said, it completely depends on your setup.
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
you mean 4th gear rev limiter correct?
