bad ignition control module or bad tps
gersain
Humble, Texas, United States
I had check engine light on when I bought the car and it was getting fuel cut and I couldn't give it any gas because then it would choke and back fire so I replaced afm(stock) and the check engine light turned off and now the car idles bad and shkes a bit and I can't give it gas because than the idle stumbles. And then rises back up to 1k I can't rev past one thousand rpm:( I think it might be the ignition contol module since it also dies out sometimes when I start it un the mornings
