all aftermarket gauges in custom panel
ghynes440
52
Pennsylvania
Just looking to see if anyone with a mk3 has done this? I was looking to get all aftermarket gauges and getting a custom gauge panel made. I would delete the whole stock cluster. If anyone has done this, was it a PITA?
ghynes440
52
Pennsylvania
I'm actually getting someone to make it for me out of fiberglass. Do you happen to have any pictures? If not I'm sure we could meet up somewhere!
trainwreck
25
doylestown, pa
All autometer massaged into the stock housings behind the clear plastic. Left to right
Water temp
Tach
Speedo still stock
Af wired to innovate lm1 which has output programmed so autometer af displays true wideband
Egt
Oil pressure
Fuel level is where the 12v port was
Boost and knock on the a pillar
IndigoMKII
2,181
Madison, Virginia
Enraged;2062420 said:
don't you need a firewall between the fuel cell and passenger compartment? you know, because of fiery death?
Where's the firewall between the stock location of the fuel tank and the passenger compartment?
