Aem ems and needed accessories
turbo87targa
482
colorado springs
So before I buy my fuel and turbo upgrades I'd like to have what I need o safely contol it all. I plan to buy the ems and a wideband already, but I'd like to get rid of my afm and possibly control boost with it. What are the aem add on things I'll need? (ie boost solenoid/ map sensor?)
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
you need air temp sensor, map sensor and boost controller soleniod(from aem tru-boost)
all these items are available from aem. good luck
Halsupramk3
444
Mississippi
aem map is high quality. goto a junk yard and get the round 3 pin connector for the map. it is commonly used for tps on many gm engines. cut that pig tail for the map sensor. you can also get a ait of many gm cars. be sure to write down what car and engine it came off of so you will know what voltage values are needed. you can get your pigtail there too.
