Hi all
I am working through the non working bits on an 89 7MGTE MA70 GT. The car has had an engine replaced and some of the wiring never seemed to find the right home.
The A/C does not work when the dash button is on even though the light is on.
I have had the A/C gassed and can activate the magnetic switch manually from the battery. The 20 amp fuse in the passenger kick panel is okay.
I have used a Factory Manual PDF for a 1990 to track through the system circuit. The A/C amplifier pins 2 and 10 should have 12v when the button is in the 'on' position, (lit up) & 0 volts when off. I have the exact reverse!
Does anyone know if the 89 and 90 systems differ this much. I cannot see how this would work.
All help appreciated.
