7MGE Valve Seals
Heggy
77
Vaudreuil-Dorion
Hi,
I was wondering of anyone has done valve seals on the subject engine, when it is in the engine compartment? If yes, which valve keeper removal tool and seal remover tools were used?
Thank you.
toyotanos
What will we break today?
2,841
Coon Rapids, MN
^^ This, very much so!
Additional key points:
Work on one cylinder at a time
Have the cylinder you're working on at TDC
Have a small magnet to grab the keepers with, it helps a lot!
Use heavy wheel bearing grease on the inside of the keepers to 'glue' them to the valve stem during re-installation.
Tap each valve stem with a brass drift to ensure proper keeper seating.
