7M-GTE on 2JZ-GTE electronics
Backlash2032
1,823
Nebraska
Is it even possible to run a 7M-GTE off of 2JZ-GTE electronics? Maybe off of IS300 electronics? I don't know the system used on those cars though... The only thing that I think would be difficult/impossible is timing. But I've also read that the signals are identical between the two engines.
KTM530
154
santa rosa
i asked this same question and i was told no, but anything is possible with enough time and money. But its easer to go stand alone and cheaper. The 2jzgte uses a hall sensor on the crankshaft (i could be wrong this is what i was told) so adapting that is kinda a pain.
As in what?
You need both sensors or manipulate the Ecu into thinking that there's 2 cam sensors.
And iirc the pick ups on the cams are in different spots.
Plus you need a crank sensor signal that is 12:1
Backlash2032
1,823
Nebraska
I was asking about the cam signals. I doubt there would be anyway to replicate the crank signal with the 7Ms cps
Sent from my terrible HTC Rezound using Tapatalk. Don't buy HTC...
