2j high rpm breakup
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Hey guys, I've been fighting a under load high rpm breakup in my vvti 2jzgte ever since I dropped in the engine happens about 5k rpm and whatever boost that happens to be, I am running megasquirt, ls2 coils cop with ngk bkr7 plugs, I've also got a walbro 400lph fuel pump, - 8 fuel line to the rail, ID 1000 CC top feed injectors with the dm top feed injector rail, I've been fighting this for a couple weeks now and I've been focusing on the ms as the issue, but now I am fairly convinced it is something else, but everything I look at looks good any suggestions would be appreciated
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
This was when they were at .030
Sent from my iPad using Tapatalk
Do you have the proper dwell times for the coils? Iirc there pretty picky but could be wrong.
You can try flipping the wires at the Ecu for the can plug and then change it from falling to rising.
If the cam is already on rising then switch the wires and go to falling.
