275/40/18 question
ghynes440
52
Pennsylvania
I've tried searching but no luck, has anyone had any luck fitting 275/40/18 on the rear of the mk3? I know 35's will fit but wanted to see if 40's will before I buy them. Thanks!
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
I'm running a 18x10.5 +22 with a 275/35 and room to go to a 40 sidewall. A 40 sidewall compared to a 35 is roughly an inch taller
You should be ok. I do have my fenders rolled and pulled aswell.
Take some measurements to make sure it'll fit your ride. If you have coilovers, they could be raised up a little to compensate
Sent from my SM-J320V using Tapatalk
ghynes440
52
Pennsylvania
Thanks! I plan on rolling and pulling my fenders also
slowma70
296
Orlando,FL
can you post some pics plz.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
gsxr141
1,158
10
rochester
not all 275-40s' are the same. they differ from one manufacturer to another, but you should be ok.
you will definitely need a roll and pull, or some negative camber.
