1uzfe v8 turbo supra mk4
customs
175
Edmonton Ab
If that tach is reading properly that means hes reving it to 8000RPM.
is that even possible with that motor?
(EDIT)
I went and did a little research and saw that this is a short stroke motor, which leads me to believe that they can be a high revving motor.
Chambers
Now you know
Sep 9, 2007
981
Baltimore County, Maryland
More than likely the tach driver is still on the 6 cylinder range, I know mine would read high when I had the 7M tach driver in.
But as it was said, the 1UZ can rev it to insane rpms when built.
