1jz turbo setup questions
1987supraturbo
Guest
hey i was wanting to kno i recently aqquired a 1jz turbo set up including both turbos manifold y pipes ect. could i sumhow put this on my 7mgte setup??? meaning could i put the twin turbo on my 7mgte easily. what would i have to do to do it??? would the manifold fit on 7mgte. thanks for everything
1987supraturbo
Guest
also are the CT12A turbos off the 1jz beter than the ct-26 off the 7mgte???? and can they been interchanged so i could use one ct-12 and one ct-26??
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
i was wondering if the 1jz (ct12a) turbos are different from the 1ggte (ct12) turbos and if so what cause if there is no diference the i could just bore my engine over to meet the hp of the 1jz right.
