HI, ive currently got an '89 MkIII with a 1jz in it. When the car was running i loved it. however, the ecu went bad and the twin smokers blew. i got the twins replaced and have a new ecu, unfortunately it's the soarer ecu and i can't find the ecu plugs to go with it, having had a jza70 ecu in it previously. It has been a bitch and a half finding and getting parts for this engine. So. after i get back from my next deployment i'm considering buying a 2jz-gte and swapping that in. i believe the motor mounts are the same, and i have an r154 tranny already. i figure between buying the engine, any additional parts i might need, and labor to install should run me between $5000-$6000.
basically, this swap would be one of convienence, since if it breaks down, i could actually find a garage close to where im at to fix the damn thing, also buying able to roll up to toyota or pep boys to get parts would be good. my question is what do you all think of this? is it worth it? i'll definitely have the money to do it. and finally, after searching, i havent found a thread that details this swap. does anyone have any info on what other parts i would need besides the wiring harness/ecu for the 2jz? im also planning on getting the 2jz fuel pump.
