Ok so my motor is fully stock and boost is at stock setting. When i am not in WOT the motor will rev up fine no problems but in WOT at 4k 5k rpm my motor hesitates to go(sounds like2 step). Im reading full boost on gauge. Ive changed coilpacks, spark plugs(gapped .28) checked my ecu for damage and changed my fuel pump. I dont have a wideband hooked up at the moment so idk my afr readings. When i took off spark plugs they were all black..What can cause this to happen? I never had this problem til now. My car did sit for a while. I thought that my coilpacks were the problem since they were all cracked. Also since it did sit for a while my motor now puffs out blue smoke at start up then goes away after getting warm. Prety sure those are just valve seals and dont think that has anything to do with the hesitation.
