So i just got a 1jz, supposedly had bhg. I can see it was blown. Basically my question in this thread is what do i do to ensure this engine reliable machining wise.. This is a used engine that was used for drifting. So i am asking ally ou gurus what would you do if it was your engine..? Rings? Hone? Decked and resurfaced? If the pistons and rods look okay that is.. Goal is 400whp reliable. I don't want to go forged if not needed for that is very expensive. Also i am missing alot of bolts for the engine. Whats a good website or place to buy bolts? Is there a bolt set for the engine? Another thing its an auto soarer 1jz ecu can that be used in my 7m? Or can i use my 7mgte harness? Again eould you go standalone or is it possible..
