1jz baseline dyno and vid
88supraTT
292
around the bend
stock 1jzgte, only thing is e6x
what do people think for this baseline? 273/265 13 peak psi with 93.9F degree intake temps
any issues or is it about on par for a possibly 20 year old engine. I'm having coil issues , just seems like power is down for 11-13 psi.
side not: wih the fuel curve its the first time ive messed with a haltech, and we did around 15-20 pulls and just got tired to doing pulls, adjustments were being really touchy. its good enough for base line i guess, we tried messing with timing and ended up losing about 10hp, so i guess its time to up grade ;)
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
Stock twins kind of low for 11-13 psi though and with a aftermarket ecu. Just for comparison my baseline dyno'd was 296/308 at 10psi stock ecu untuned.
Zach
ECUMaster USA
Apr 6, 2005
375
TX
88supraTT;1374195 said:
anyone have any ideas as to why it would be lower then most other cars?
Because the intake temps were high?
Exhaust and intercooler setups will make a difference, as well. Different dynos read very differently, also. Sounds like a fine number to me and it'll serve as a baseline for you to compare with as you progress.
88supraTT
292
around the bend
^ i was just stating intake temps as a reference, it was about 95-96 degrees in the dyno area.
I guess its just a baseline, hopefully in the coming weeks i'll be putting on a pt4067. :)
