Stock 1jz
stock cams
8 blade Holset wh1c
custom ITB intake
Megasquirt 3
e47.5 (50% 93 50% e85)
835cc injectors
Twin Bosch pumps
This was 20psi peak boost. it was falling off because I dont have a boost controller. to up the boost we added vacuum tee's to the vacuum line gong to the wastegate. I paid $150 for this turbo from Craigslist. The Stock 1jz intake seems to the the reason power falls on its face on these motors. I plan on adding 2jz cams, a boost controller and running pure e85. then see if I can up the boost to about 28psi
The intake was a custom piece made locally, the revs are insane! I expect hp and tq to be even closer when I up the boost. definatly over 500 foot lbs.
Ive been through precision, garrett GT, Borg Warner, Turbonetics and these Holsets are by far my favorite. you can see more on my ITB setup in my old build thread.
http://www.supraforums.com/forum/sh...cooler-Individual-throttle-body-6-speed-setup
stock cams
8 blade Holset wh1c
custom ITB intake
Megasquirt 3
835cc injectors
Twin Bosch pumps
