1j o2 wiring???
478slimm
58
Georgia
I have a 1j non vvti in my 89 mk3, my 1j came with the 3 wire o2 sensor, 1 blue wire and 2 black wire. I need to know what each of those wires are. I have a tweakd wiring harness and they used the 4 wire plug with O2 heater, and 1 is just o2(im guessing thats the signal???) And + and -. How cam i wire them together???
f00g00
586
Kuwait
I would call Doc Tweak and have him send a 3 wire plug that you can swap over or use a 7M after cat O2 sensor which is 4 wires.
478slimm
58
Georgia
Sorry but yes I have the 4 wire connector I just don't know what each of the 3 wires are on my o2 are, I can't find anything or diagrams. 2 black wires and above those pins in the middle is 1 blue wire
The 2 black wires are for the heater and the the blue is for the signal. The sensor is grounded through the manifold.
478slimm
58
Georgia
Sorry man for the late reply, I've been gone for over a month due to work. I already have the pin out for my plug from tweakd. The plug has a ground, 12v, heater circuit, and signal. Should I wire both heater(black wires) together and is the 12v not needed???
Radial
252
Norway
In short: If you have a 4-wire o2 engine harness, you need a 4-wire o2 sensor.
The problem is that a 4wire setup has its own o2 signalground (not grounded through engine/exhaust)
If this engine harness signalground is shorted to engine ground, you could in theory have used a 3-wire o2.
But... engine grounds are quite noisy, and will send noise directly in to ECU through the o2 signal gnd. This in turn might fuck up TPS, MAP signals etc...a real mess.
So in short, dont do it.
Install a 4 wire sensor, and call it a day.
