Hey all, I'm having an issue with my 97 4runner and its driving me nuts. Here's how it started: I had been driving on the freeway and went.from 60mph to 90mph and then I let go of gas, once the done reached idle speed, car stalled and shut off. Even after starting the vehicle it wouldn't remain on at idle speed unless I gave it gas to 1500rpms+. I managed to make it more manageable by adjusting the Allen bolt on the throttle body so that it would not die while driving.
To resolve the issue I have the following:
Purchased and replaced fuel filter
Purchased and replaced spark plugs
Took off the throttle body and used throttle body cleaner to remove grime buildup.
After doing the above the car started "ok" but I know for sure that on a complete cold start the issue may continute. I don't believe it has anything to do with actual the actual cold start system but I'm open to just about anything right now.
No cracked hoses, none ripped either. I'm appreciative to what anyone has to say or if anyone has dealt with a similar issue. I thought it first to be fuel pump but I think that it would cut out after being warm rather then just initial starts.
Thanks all, Dimitris
Sent from my ADR6400L using Tapatalk
