Powered by Team Mondor
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Camber adjustment .....
  1. #21
    Regular Member
    Join Date
    Nov 2007
    Location
    NY
    Posts
    391
    Default Re: Camber adjustment .....
    on my subframe the prvious owner somehow bent the tab on subframe for camber. i plan on getting adjustable camber arms will that be enough to fine tune camber
  2. #22
    hvyman's Avatar
    Join Date
    Apr 2007
    Location
    Posts
    12,579
    usually when the tabs are bent the bolts and bushings are seized together making it impossible to align.
    If you going to replace the arms. Set the camber arm cam bolt to the most positive position so the cam will be pushing on the tab that's towards the outside of the car and then adjust the camber with the arm.
  3. #23
    Supramania Regular
    emiliorescigno's Avatar
    Join Date
    Sep 2006
    Location
    Woodbury, MN
    Posts
    1,213
    Holy thread bump batman.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
