Powered by Team Mondor
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Supra Head Flow (5M,7M,1JZ,2JZGE,2JZGTE)
  1. #11
    suprahero's Avatar
    Join Date
    Aug 2005
    Location
    Posts
    14,969
    Default Re: Supra Head Flow (5M,7M,1JZ,2JZGE,2JZGTE)
    stuck.
    FEAR A GOVERNMENT THAT FEARS YOUR GUN
    http://www.break.com/index/one-of-th...-made-2218472#
  2. #12
    Junior Member
    rwd's Avatar
    Join Date
    May 2008
    Location
    quebec
    Posts
    60
    Quote Originally Posted by ma71supraturbo View Post
    As I posted -- the only data I've found is from Erin Carpenter. Here is his post on SF:
    http://www.supraforums.com/forum/sho...d.php?t=339560
    the flow of 2jz stock head that Erin Carpenter flowed is not same as my friend 2jz stock head?
    for intake port ,at .400, my friend had 215cfm and after port&polish he had 234cfm???
    bizarre
  3. #13
    Supramania Regular
    ma71supraturbo's Avatar
    Join Date
    Mar 2005
    Location
    Redding, CA
    Posts
    975
    Quote Originally Posted by rwd View Post
    bizarre
    That is part of the problem with comparing flow numbers. People have reported their 2JZs flowing anywhere from 215-250 stock just because of differences in flowbench calibrations (with 230 being the average). Since Erin Carpenter presumably flowed both heads on the same equipment -- then the percent differences (at that one lift) should be accurate. Still, the 1JZ data is woefully lacking, and I welcome any new information/numbers that people may have.
  4. #14
    bobb'n for money
    bobiseverywhere's Avatar
    Join Date
    Apr 2005
    Location
    Montreal
    Posts
    1,990
    i am not to sure how that keeps happening with the rumor about the 1J. the only thing the 1J head has over the 2J is air Velocity as i understand it. it may flow less but it flows the air at a higher velocity. That's what i have understood from tid bits here and there i don't know if anyone has data to back this up. Possibly this theory is based on the shape of the ports. not to sure anymore.
    "There is no excellent beauty that hath not some strangeness in the proportion."
    -Sir Francis Bacon
    Maplemicro my little computer biz
  5. #15
    Stock is boring :(
    tissimo's Avatar
    Join Date
    Apr 2005
    Location
    Melbourne, FL
    Posts
    4,223
    Quote Originally Posted by bobiseverywhere View Post
    If you look at the 1jz ports (intake) vs the 2jz, you'll see why the velocity is higher. The ports are smaller and with smaller ports you'll have higher velocity with similar flow (lower lifts). But of course with a smaller port and you run out of flow faster then the larger.
    98 Toyota Supra Turbo
    92 Toyota Supra Turbo
    92 Toyota Celica Alltrac
    90 Toyota celica Alltrac
  6. #16
    Junior Member
    rwd's Avatar
    Join Date
    May 2008
    Location
    quebec
    Posts
    60
    if i port&polish 1j head, is it possible to acheive the same results as 2j
    i think 2j can flow about 300cfm with crazy job
  7. #17
    Droppin that JZ in soon!
    Guyana00's Avatar
    Join Date
    Apr 2007
    Location
    Brampton, ON
    Posts
    1,211
    Anyone notice the difference in flow when it comes to intake and exhaust when comparing the 7m and 1j? 7m looks much better than the 1j for exhaust and the 1j looks better than the 7m for intake.
    Warning: Speed ratings apply only to the tire, not to the vehicle. Putting a speed rated tire on any car does not mean the car can be operated at the tire's rated speed.
    1994-2006 Yokohama Tire Corporation. All rights reserved.
    86.5 N/A Hardtop 5spd. - Parted and scrapped. *R.I.P.*
    87 N/A Hardtop 5spd. - *SOLD* - 07/15/08
    87 N/A Targa 5spd. - Garaged - Sourcing Swap Parts
    91 JZA70 Hardtop 5spd. - *SOLD* - 06/07/09
    87 Turbo Targa 5spd. - Parted and scrapped.
  8. #18
    Supramania Regular
    SupraClaou's Avatar
    Join Date
    Sep 2006
    Location
    Athens,Greece
    Posts
    833
    Head job (port & polish) should be done only when you wanna push
    big HP numbers...
    Some guys stated that a ported head will start to 'pay off'
    only after 700-800 whp...at least on a JZ engines
    Till then the stock head is more than ok
    ''In the end there will be only one car standing.
    Toyota Supra...simply the best""
    R.I.P. Giagia (grandma)
  9. #19
    DONT BE A BITCH!
    hottscennessey's Avatar
    Join Date
    Jun 2005
    Location
    Richmond, VA
    Posts
    3,138
    good info for the 2JZGE. I'm surprised how close the 2JZGE is to the GTE despite the obvious differences in heads.
  10. #20
    Interdimensional
    RacerXJ220's Avatar
    Join Date
    Mar 2005
    Location
    Abalama
    Posts
    1,492
    We know we can make 700WHP+ on most of those heads stock flow. I wonder what the limit would be for the 1JZ exhaust port assumed max flow.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
