Powered by Team Mondor
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 7MGTE from Malta - build up thread
  1. #11
    Lurker
    Join Date
    Apr 2009
    Location
    Midway to Nowhere
    Posts
    11
    Default Re: 7MGTE from Malta - build up thread
    Quote Originally Posted by IJ. View Post
    Got a pic of the header off the car Joe?
    (having the Turbo discharge pipe between the runners confused me)
    Engine looks really sad
    here it is:
    believe me Ian, I am way much sadder than the engine now!!!
  2. #12
    Lurker
    Join Date
    Apr 2009
    Location
    Midway to Nowhere
    Posts
    11
    I wouldn't chance that Gasket.
    that's another bad news!!!
    Since last time we talked, I made a huge change of plans, to the extent of getting a smaller turbo and keeping the stock head.
    However I am still going for the Pauters and the custom coated Ross.
  3. #13
    IJ.'s Avatar
    Join Date
    Mar 2005
    Location
    Posts
    39,070
    Well that is truely unique Joe!
    How long did the engine run before it grenaded?
    It's hard to tell which came first with the chamber, I'd guess it's Oily from the Torched piston but those bearings look like they've done 300,000 Km's
    Heading out to the shed now I'll check in at lunchtime.
  4. #14
    Lurker
    Join Date
    Apr 2009
    Location
    Midway to Nowhere
    Posts
    11
    Turbonetics T66 and Trust T88H38GK:
  5. #15
    Lurker
    Join Date
    Apr 2009
    Location
    Midway to Nowhere
    Posts
    11
    The engine has almost 2500 miles on it. It was running fine at 13psi until one sudden boost spike at 17psi. When it started to slightly breath blueish smoke, still the smoke didn't suggest this extent of damage!!! Believe it or not, there was almost no blue smoke from the exhaust!! Just a slight hint.
    The bearings are from rods 4 and 6, those I guess are my fault for not upgrading the oiling system.
    I'm off to sleep since its 2 in the morning here.
  6. #16
    Lurker
    Join Date
    Apr 2009
    Location
    Midway to Nowhere
    Posts
    11
    Finally, after more than a year I'm back on my supra project.
    Some photos attached.
    Attached Images Attached Images
  7. #17
    Aliens.
    CyFi6's Avatar
    Join Date
    Oct 2007
    Location
    Phoenix
    Posts
    2,976
    Wow was the head re-welded and machined? Looks clean, but the combustion chambers dont look stock and some of them look different than others, as well as some coolant passages misshaped.
  8. #18
    Lurker
    Join Date
    Apr 2009
    Location
    Midway to Nowhere
    Posts
    11
    Quote Originally Posted by CyFi6 View Post
    Yes, in fact head was re-welded and machined, could not find a spare head.
    The chambers are smoothed, mildly re-shaped and cc'd. They are exactly the same shape as a deck template was used.
    Coolant passages are far from their original shape but that's a minor issue which does not really effect flow as such, so it is overlookable.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
