Powered by Team Mondor
Results 1 to 2 of 2
Thread: No BOOST ??????
  1. #1
    Lurker
    Join Date
    Feb 2009
    Location
    kent
    Posts
    Default No BOOST ??????
    Hi i'm a newbie and have just got a mk3 manual turbo.
    Had a bit of work to do as the head needed helicoils all done and back together now but can't get any boost i broke the green plug off of the thermostat housing would that cause the problem as i also have an engine management light on but no codes. Please help.
    Many thanks
  2. #2
    That Limey Bastard
    Kai's Avatar
    Join Date
    May 2006
    Location
    Portslade, England
    Posts
    3,135
    Default Re: No BOOST ??????
    If you have an engine management light showing, you DEFINITELY have codes. Are you reading them with the paperclip trick, and if so, are you making sure that it's actually making adequate contact?
    Also, could you please take a picture of the thermostat housing, so i know what exactly you're referring to
    1990 Toyota Supra Mk3, 2954cc 7M-GTE, Lexus AFM, 550cc RC Injectors,
    FSE 255lph Fuel Pump, 7M-GE FPR, Turbo Technics Stage 1 Hybrid CT-26,
    HKS LET-16 Exhaust System (Elbow Back, DeCatted), Bailey Motorsports DV30 BOV,
    Samco Hose Set, Custom Intercooler, 10-row Mocal Oil Cooler,
    HSD Coilovers, 16" MkIV 5-spoke Alloys w/ Toyo T1-R's
    "DreamerTheresa: If i had a penis, it would have just crawled into my stomach out of fear."
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
