Powered by Team Mondor
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Adjusting tokico illumina 2 for tems
  1. #1
    Boostin USA
    7thousandpiecesMGTE's Avatar
    Join Date
    Apr 2007
    Location
    Harford County, Maryland
    Posts
    476
    Default Adjusting tokico illumina 2 for tems
    Just installed them all the way around with eibachs, the shocks did not come with the plastic cap indicators, but i know the flat part on the shaft is the 5 position. I have searched my ass off but could find a thread on this:
    The adjuster just spins all the way around and doesn't stop. there is no difference on the little metal pin to show which way its adjusted to. If i think its on position 1 it could be on position 3 or vice versa. the instructions say nothing about how its supposed to be adjusted when installed.
    Can they be adjusted to far? is there a better way of making them all the same other than trial and error?
    Can anyone shed some light please?
    -Andrew
  2. #2
    Supramania Regular
    Join Date
    Apr 2005
    Location
    Philly
    Posts
    735
    Default Re: Adjusting tokico illumina 2 for tems
    There's a diagram in the TSRM.
  3. #3
    Boostin USA
    Join Date
    Apr 2007
    Location
    Posts
    476
    Quote Originally Posted by Wiisass View Post
    So it cant be done backwards? if i have all the metal adjusters inline with the bolt holes for the actuator they will all be tuned in the same (firm)?
    -Andrew
  4. #4
    addicted to toy's
    toy fanatic78's Avatar
    Join Date
    Oct 2008
    Location
    Elkhart,IN
    Posts
    702
    Quote Originally Posted by 7thousandpiecesMGTE View Post
    ? TEMS only has three positions.
    old school toy's for life!
    86.5 supra,in the works
    84 cressida built 5m lotsa mods
    r.i.p. mk2's #1-5
  5. #5
    Boostin USA
    Join Date
    Apr 2007
    Location
    Posts
    476
    Quote Originally Posted by toy fanatic78 View Post
    I bought the illumina II's which i thought were 5 way adjustable but it says for supra w/tems...... so does this mean its only a three way adjustable shock then?
    -Andrew
  6. #6
    Supramania Regular
    Join Date
    Apr 2005
    Location
    Philly
    Posts
    735
    I don't know anything else about these things. I think they're fine either direction, but can't say for sure. But I'm pretty sure that's how the stock tems are.
    But you bought these and don't have TEMS? So why did you buy them?
  7. #7
    Boostin USA
    Join Date
    Apr 2007
    Location
    Posts
    476
    I do have tems. Maybe these are made to be exact oem replacements and they are only three way adjustable. Not trying to be dense, just thought i would get more adjustablilty out of them and i guess i am over complicating this....
    someone who knows for sure feel free to chime in and set me straight, thanks.
    -Andrew
  8. #8
    addicted to toy's
    Join Date
    Oct 2008
    Location
    Elkhart,IN
    Posts
    702
    I do believe you're correct on that.AFAIK they are just orientated in the three directions,doesn't matter if they are 180 degrees difference.
    r.i.p. mk2's #1-5
  9. #9
    Lurker
    Join Date
    Feb 2013
    Location
    San Diego, CA
    Posts
    17
    OP, did you run into any issues with the adjuster being 180 degrees off? I had the exact same question about the adjuster on the Tokico Illumina 2 shock.
    I called Tokico and they told me it was 5-way adjustable and if I turn all the way clockwise it would stop and that would be most firm. I tried that but it keeps spinning and never stops... so perhaps it is only 3 way adjustable...
  10. #10
    hvyman's Avatar
    Join Date
    Apr 2007
    Location
    Posts
    12,578
    Thread is 5 years old and op last logged in in 2012.
    You need to keep turning them. Its not like coil overs where they adjust 1/8 turn.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
