Powered by Team Mondor
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Stock/Lowering Spring Rate Compilation
  1. #1
    Supramania Regular
    Join Date
    Feb 2006
    Location
    NJ
    Posts
    1,871
    Default Stock/Lowering Spring Rate Compilation
    Here's a list of lowering spring rates that have been found over the net. I recently found out the rates of the Stock MKIII Pre-89s and the Whiteline Springs, so I've added them here along with the other list. I'll try to find out the spring rates from various companies in the future. I got the Whiteline Spring Rates from an email from a Whiteline Customer Service person, so it's reputable. And as for the Stock MKIII Pre-89s, they seem plausible as a site said they are 16% softer than the Stock MKIII 89+. Before anyone says Tanabes are linear, they are not. While I have no personal experience with them, I emailed Tanabe and a rep said they are progressive in some areas, and linear in others. This means its progressive since its not one set spring rate, as far as I can tell.
    There are some debate about the stock MK3 springs. Some manufacturers who give out rates say the rates are 15-30% more than stock which would actually lead the 89+ springs to be around 390 lb/in in the front and the 87 springs to be around 330 lb/in in the front. But most really wouldn't care about the stock spring rates because it's still 4x4 height and stuff.
    * Stock MKIII Pre-89
    * Front: 461 lb/in
    * Rear: 180 lb/in
    * Drop: It's higher than the Stock MKIII 89+
    * Type: Linear
    * Stock MKIII 89+
    * Front: 461 lb/in
    * Rear: 215 lb/in
    * Drop: 0
    * Type: Linear
    * Stock MKIV
    * Front: 430 lb/in
    * Rear: 219 lb/in
    * Drop: 0
    * Type: Linear
    * Notes: Only the front MKIV Springs will fit our cars.
    * Eibach
    * Front: 343-628 lb/in
    * Rear: 126-257 lb/in
    * Drop: 1.3" - 1.0"
    * Type: Progressive
    * Suspension Techniques
    * Front: 442 lb/in
    * Rear: 147-175 lb/in
    * Drop: 1.3"
    * Type: Linear Front, Progressive Rear
    * H&R
    * Front: 575 lb/in max
    * Rear: 285 lb/in
    * Drop: 2"
    * Type: Progressive
    * Tanabe
    * Front: 442 lb/in
    * Rear: 207 lb/in
    * Drop: 1.1" - 0.6"
    * Type: Progressive
    * R*SR Race
    * Front: 677 lb/in
    * Rear: 335 lb/in
    * Drop: 1.4" - 0.8"
    * Type: Linear
    * R*SR Sport
    * Front: 503 lb/in
    * Rear: 262 lb/in
    * Drop: 1.2" - 0.8"
    * Type: Linear
    * Tokico
    * Front: 395 lb/in
    * Rear: 198 lb/in
    * Drop: 1"
    * Type: Linear
    * Whiteline
    * Front: 381 lb/in
    * Rear: 218 lb/in
    * Drop: 1.0
    * Type: Linear
    * Intrax
    * Front: 700 lb/in max
    * Rear: 220 lb/in
    * Drop: 1.6" - 1.3"
    * Type: Progressive
    * B+G Suspension
    * Front: ?? lb/in
    * Rear: ?? lb/in
    * Drop: 1.3"
    * Type: Progressive
    * Notes: Said to have similar spring rates to Eibachs.
    * Apexi
    * Front: 626 lb/in
    * Rear: 240 lb/in
    * Drop: 1.3"
    * Type: Progressive
    * Aerospeed
    * Front: ?? lb/in
    * Rear: ?? lb/in
    * Drop: ?
    * Type: ?
  2. #2
    7M Powered
    7Mboost's Avatar
    Join Date
    Aug 2006
    Location
    Gainesville, FL
    Posts
    2,202
    Default Re: Lowering Spring - Spring Rate Compilation
    For the spring rates listed that vary, when/why do they vary?
    1991 Supra- 7M
    1992 SC300- 1.5JZ
    www.imvfilms.com
  3. #3
    addicted to toy's
    toy fanatic78's Avatar
    Join Date
    Oct 2008
    Location
    Elkhart,IN
    Posts
    702
    How would you test/find out spring rate for springs that aren't listed?
    old school toy's for life!
    86.5 supra,in the works
    84 cressida built 5m lotsa mods
    r.i.p. mk2's #1-5
  4. #4
    Join Date
    Jan 2006
    Location
    Alachua, FL
    Posts
    4,271
    How about the JDM TTR Spring rates?
  5. #5
    addicted to toy's
    Join Date
    Oct 2008
    Location
    Elkhart,IN
    Posts
    702
    I was wondering about the TRD's I have.AFAIK there are at least 2 different rates for the MK3 springs they made too.
    I think they are different than the re-badged Enkei's too,'cause they dropped the car almost 3" from stock
    r.i.p. mk2's #1-5
  6. #6
    Supramania Regular
    Join Date
    Feb 2006
    Location
    NJ
    Posts
    1,871
    Quote Originally Posted by 7Mboost View Post
    If I understand your question correctly, some are progressive, some are not...which causes them to have a spring rate "range".
    Quote Originally Posted by Doward View Post
    Unfortunately I do not know. They're probably stiffer than the stock springs since they're paired up with Bilsteins.
  7. #7
    Far From Maddening Crowds
    Piratetip's Avatar
    Join Date
    Dec 2005
    Location
    MKE, WI
    Posts
    859
    Thanks MA70!
    I have been trying to find the rates of the whitelines for awhile.
    You must have found someone intelligent there, when I contacted them, they had no idea.
    I rebuild / upgrade Supra Differentials - PM me for more information.
    1 Piece Driveshaft Information
    Critical Speed Calculator
  8. #8
    Supramania Regular
    Join Date
    Feb 2006
    Location
    NJ
    Posts
    1,871
    Quote Originally Posted by Piratetip View Post
    Thanks MA70!
    Hah, this lowering spring rate compilation has been up for awhile. You must have been waiting for a LONG time. :P
  9. #9
    Piratetip's Avatar
    Join Date
    Dec 2005
    Location
    MKE, WI
    Posts
    859
    Hmm, haven't noticed until now.
    Either way, still good.
  10. #10
    Supramania Regular
    Canuckrz's Avatar
    Join Date
    Jan 2009
    Location
    Calgary, Alberta
    Posts
    886
    H&R's site says it lowers 1.6" in the front and 1.3" in the back. Is the figure on their site incorrect? Because it seems you certainly did your homework.
    Here's the link to the specs on the H&R site: http://hrsprings.com/scripts/appguid...TA%20|%20Supra
    1988 Supra 7M-GTE R154 Trust 20G
    2004 Forester XT EJ255 5MT
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
