Powered by Team Mondor
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: AEM EMS .cal files
  1. #21
    Lurker
    Join Date
    Aug 2013
    Location
    Kansas
    Posts
    5
    Default Re: AEM EMS .cal files
    Anyone have some similar map i got to putter a couple times but i know something is up
    AEM V2
    1jz w/ bw s366
    denso 850cc
    stock head
    255 walbro
    gm iat
    gm 3 bar 12223861
    stock coils
  2. #22
    7m Love
    raysupra's Avatar
    Join Date
    Jan 2010
    Location
    Mustang, OK
    Posts
    71
    This is the Auto base file I was given
    6100 Supra Auto Trans Test LATEST.01V24.cal
    -Parker-
    1983 MKII:-Built 7m/ffim/AEM EMS2/AEM FPR/AEM Cam Gears/Billet BWS366/Tru-trac 3.73/x2 Wally e85/-8 feed/LQ9/2150cc injectors
    DD 14 Chevy 4x4//Sold 86 mk2//Sold 85 MKII //Sold 90 MKIII
  3. #23
    Supramania Regular
    Join Date
    Oct 2010
    Location
    rochester
    Posts
    1,153
    Quote Originally Posted by Pyro15D View Post
    Hey here is mine. It works pretty well. Here is what I have:
    1987 Supra Targa 7mgte
    Stock ignition coils and ignitor
    Stock engine internals and manifolds minus 2mm MHG and ARP head studs
    Greddy intercooler
    Tial 50mm BOV
    HKS 3000 pipe
    Boss Jr. 60-1 Ball bearing turbo
    3 inch exhaust with HKS Super Drager
    Action Clutch 2800 lb pressure plate with stock disc
    560cc injectors
    43psi fuel pressure with vacuum line disconnected from AFPR
    GM 3-bar MAP sensor
    Uses the fuel pump resistor relay signal to drive the radiator fan on output LS1
    Set ignition timing to the standard 10 degrees BDTC like with the stock ecu.
    It starts within a second of cranking every single time and idles at 775 rpms when warm. I've tuned it myself using bits of maps from the base tune and other fuel and ignition maps I've googled. This is the best I've been able to come up with so far without any professional help. I just drove 1200 miles over the weekend on this map and got 23 mpg with it. I know it isn't the best I could get with it, but it is a decent starting point for you all out there. If any of you are professional tuners and you look at this map, I am open to all comments you might have to squeeze more out of this motor. I've only pushed it to 15psi (which was today) and it didn't knock, so that's good. I am running premium 93 octane E10 (since buying gasoline without any ethanol in it is illegal in Washington State for some stupid reason) and it was around 75 degrees outside when I did the datalog. Hopefully this is enough info for you all to go off of. Just trying to give back to the community who has given me so much.
    Cal file:Attachment 68556
    Datalog:Attachment 68555
    hey all. i', having my aem ems installed this weekend. i don't have a base map for it. will something like the one listed here work?
    my mods are............ stock block with arp studs.
    630 injectors
    bic ddp, full 3", no cat
    60-1 ct 26 11psi actuator
    greddy profec b spec 2
    afpr and wally 255 to be installed saturday
    aasco flywheel
    1 pc driveshaft
    thanks in advance
  4. #24
    Lurker
    Join Date
    Apr 2014
    Location
    Dammam
    Posts
    Hi,
    I need start-up file for 1jz turbo, Japanese version.
    every thing is stook, using 2jzgte harness Japanese version as well
    I tried to startup the car with the files those come with the ecu and didn't start
    AEM V2.
    Thanks,
  5. #25
    Lurker
    Join Date
    Nov 2013
    Location
    Ont
    Posts
    4
    aem v2
    Aristo 2jz-gte vvti
    stock 440's
    stock vvti coils
    single turbo
    gm temp sensors
    no vvti settings.
    Just a start up map, only very mild driving https://drive.google.com/file/d/0B-P...ew?usp=sharing
    Attached Files Attached Files
  6. #26
    suprahero's Avatar
    Join Date
    Aug 2005
    Location
    Posts
    14,969
    What do I need to download to be able to see these maps. I downloaded the AEM.ems and every time I click on one of your maps, it tells me that the version I downloaded doesn't work with this. Thanks.
    FEAR A GOVERNMENT THAT FEARS YOUR GUN
    http://www.break.com/index/one-of-th...-made-2218472#
  7. #27
    Lurker
    Join Date
    Nov 2013
    Location
    Ont
    Posts
    4
    you need AemTuner for series 2 (v2) maps and AemPro for series 1 maps.
    http://aemelectronics.com/?q=product...ware-downloads
  8. #28
    Supramania Regular
    seoul4korea's Avatar
    Join Date
    Nov 2008
    Location
    Panama City, Florida, United States
    Posts
    585
    Anyone have a .cal file for a 1J non-vvti with stock injectors? I had mine running and as soon as I uploaded the DM file it stopped. I can't seem to get it running again and it's pissing me off.
  9. #29
    Lurker
    Join Date
    Nov 2011
    Location
    Maryland
    Posts
    5
    So I'm in real need of a base map so I can get my car started from the swap and be able to diag it if something is wrong and be able to break my clutch in before actually getting it tuned. Anybody on here by chance able to help me out? 1jzgte non-vvti AEM V1 (model 30-1100 mk4 box) Mods are as follows. Any help would be much appreciated thanks in advance
    •tweakd jumper harness to chaser harness
    •93 octane base map
    •1jz stock throttle body
    •Stock cam/stock motor
    •Siemens deka 850cc high impedance injectors top feed (so that resistor pack is not needed)
    •Warlboro 430lph pump
    •Aem 5 bar map sensor
    •Mac valve for boost control
    •GM iat sensor
    •Single Turbo is a 66/73 garret hybrid journal bearing. 70/ar compressor side t4 .81/ar hot side
    •Plugs are the ngk bkr7e
    •Going to be Using hks dli but not currently installed yet
    •Stock coil packs
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
