Powered by Team Mondor
Page 7 of 7 FirstFirst ... 34567
Results 61 to 70 of 70
Thread: Official emanage ultimate thread
  1. #61
    Supramania Regular
    mk3_7m's Avatar
    Join Date
    Jul 2007
    Location
    melbourne
    Posts
    539
    Default Re: Official emanage ultimate thread
    ultimate
  2. #62
    Junior Member
    Join Date
    Aug 2009
    Location
    Ann Arbor
    Posts
    161
    Default Check out this MK III wiring schematic for the Emanage Ultimate
    I just made a wiring diagram for how I plan to graft my EMU into the supra wiring, including three add on gauges for EGT, Volts, and AFR, and aftermarket k-type egt probe, plus the Zeitronix Zt2 datalogging and wideband box. I have set it all up so that the unit is grafted in via modular connectors I ordered from Radio Shack online. It can be removed or bypassed by moving a few connectors. I also have the gauges, with dimmable lighting, on a separate connector. The wires T-connected into the ECU harness are on a separate connector than the wires that are cut and have their signals modified through the EMU. This allows the cut wires to be reconnected, but still leaves the patched in wires available on a modular connector for convenient testing and data logging. Be warned: I haven't done the install yet, so there may well be errors. I tried to check everything carefully and went through every manual and online source I could find to get it right. It is a very complicated diagram when all is said and done, surprisingly so. I just sharing in case anyone can use a starting point for planning their own installation. THe file is easily downloaded and modified with just excel, no drawing program needed - I used simple character graphics. I hope this helps someone someday. Please PM me with requests for clarification and to notify me of errors or improvements, since I'm only on here occasionally.
    https://docs.google.com/file/d/0BxPT...it?usp=sharing
    Good luck with your installs!
    K&N filter to Lexus AFM | 660cc RC | Holley 255 LPM FP | JE/Eagle internals | 2.5" hard pipes | Toyo high flow intercooler| S Sanchez ported head | 1.2mm beaded MHG | compression 9:1 w/0.5 overbore | modified ex mani | CXR 3" full exhaust | Slotted/drilled rotors |New WG spring @12psi w/ dual switching man boost | Colt Mild perf. Cams | Bosch BOV | XTD clutch | Tokico Illumina w/TEMS | ES bushings | 18" Pirelli P-zeros | Man AFPR
  3. #63
    Lurker
    '90mk3's Avatar
    Join Date
    Apr 2014
    Location
    Orlando, Fl
    Posts
    32
    Is there a specific jumper setting on the e-manage ultimate itself for the 7mgte ecu connect?
  4. #64
    Regular Member
    Join Date
    Nov 2013
    Location
    Princeton, TX
    Posts
    262
    Anybody have the software that came with the unit? I can seem to locate my disc. If you have it and can make an ISO out of it let me know.
    Chris
    1987 Turbo with aftermarket sunroof
    3" full turbo back exhaust and cats deleted, Innovate wideband, Thrush welded muffler, RFL BOV, polished charge pipes, Lexus AFM, A-FPR, 550cc injectors, 255LPH fuel pump with 12V mod, Electronic boost controller. - Not going to go crazy with the supra, I got a CRV for that. Fully built and turbo B20 shooting for 600-750WHP.
    Sold - CRV build pictures - Never did a build thread per say just took a few pics along the way through multiple things. Did not take pictures during the motor build up, kinda slipped my mind. Link is here http://s79.photobucket.com/user/Sk8t...0in%20progress - Sold
  5. #65
    Supramania Regular
    seoul4korea's Avatar
    Join Date
    Nov 2008
    Location
    Panama City, Florida, United States
    Posts
    589
    Quote Originally Posted by Chris_87_Turbo View Post
    Chris
    Chris, if you have your Unit Serial number you can get a hold of Greddy and they will email you the files you need.
  6. #66
    Regular Member
    Join Date
    Nov 2013
    Location
    Princeton, TX
    Posts
    262
    I have to get to it. Right now it's on an old Honda build. (I know it's a Honda, but there aren't too many 700 plus whp crvs running around). Ended up selling to a buddy before I could actually get a good dunno run other than the tuning runs which I can't find the printouts anymore.
    Chris
  7. #67
    Lurker
    Join Date
    Jan 2012
    Location
    Ann Arbor, MI
    Posts
    Default Re: Check out this MK III wiring schematic for the Emanage Ultimate
    Updated: Engine is working with EMU - updated wiring diagram and jumper settings.
    I have all the inputs and outputs on the EMU verified by DVM or oscilloscope except the IgF modification circuit. When I bypass the added circuit and connect IgF from Ignitor to TCCS ECU normally, my care is running nicely with EMU controlling the injectors, ignitor, AFM signal. This is currently set up with stock AFM and injectors. I have an updated wiring diagram, along with my jumper settings in the Excel file below. The software setup parameters I'm not posting because I'm not done playing with all the options. Also, my car has no tune on it now, this is just a straight 1:1 input to output mapping to get the car running and recording data through the EMU unit to the laptop. This will be my first time tuning, and I'm planning on paying someone to get the basic tune in place. I would love to hear from someone else working on tuning their car with EMU. PM me if you want to compare notes.
    This is the updated file, please disregard the earlier link.
    https://drive.google.com/file/d/0BxP...it?usp=sharing
  8. #68
    Regular Member
    Join Date
    Nov 2013
    Location
    Princeton, TX
    Posts
    262
    I did a few Hondas. It's fairly easy if you take the time to research and the patience to mess up a little. Just remember make small adjustments at a time. I got lucky and had access to the knowledge of the best Honda tuner in this half of the country when I was tuning mine
    Chris
  9. #69
    Lurker
    Join Date
    Jan 2012
    Location
    Ann Arbor, MI
    Posts
    Yeah, this is the fun part. I have had trouble finding a tuner with experience with this type of car in Michigan, but there is enough published and online that I'm not worried. It's nice to have a piggyback unit that starts from the stock tuning, and a car to tune that has some much information available.
    Got the IgF signal mod working - bad solder joint, so now I can say my wiring diagram and jumper settings appear to be functional.
  10. #70
    Regular Member
    Join Date
    Nov 2013
    Location
    Princeton, TX
    Posts
    262
    That's a good thing. I'm gonna install the EMU I have on the supra one of these days. It's either that or megasquirt
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
