Powered by Team Mondor
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: 2JZGTE Wiring
  1. #1
    Lurker
    Join Date
    Jan 2008
    Location
    Fort. Lauderdale
    Posts
    32
    Default 2JZGTE Wiring
    I have just installed my 2J and now I would like to start it before running the wires nice an neat. Can someone help me as to what wires gets connected.
    I know there`s suppose be an heavy 2 gage wire from battery positive to alternator and starter. But i need to wire up the ECU, ignition and alternator.
    Any help would be greatly appreciated.
    Thanks,
    Andre
  2. #2
    Supramania Regular
    crazysupra2JZ's Avatar
    Join Date
    Nov 2006
    Location
    Georgia
    Posts
    740
    Default Re: 2JZGTE Wiring
    ha, good luck. it's really not as hard as you might imagine. best thing you can do is print out a copy of a 90 tsrm ecu wiring diagram and a 95 ecu diagram. there are stickies that have links to ecu pinouts, you will need those too. just get a multimeter and compare the two diagrams, you'll get it eventually.
    2011 Dodge Ram 1500 Laramie - 1990 Toyota Supra Turbo
  3. #3
    Lurker
    Join Date
    Jan 2008
    Location
    Fort. Lauderdale
    Posts
    32
    Quote Originally Posted by crazysupra2JZ View Post
    Yes, thanks. I was just wondering if anyone had already done it so it would make it alittle easier.
  4. #4
    Ninja Editor 'Since 05'
    tlo86's Avatar
    Join Date
    Jul 2005
    Location
    Colorado
    Posts
    3,929
    crazy has twice now Lol. i paid dr tweak to do mine
  5. #5
    Stock is boring :(
    tissimo's Avatar
    Join Date
    Apr 2005
    Location
    Melbourne, FL
    Posts
    4,223
    what engine harness do you have? if you have an aristo look for Satan's thread about wiring peer review, the last few pages has all the info I have on it (i have gotten my buddys 88 to run on the aristo ecu & harness)
    98 Toyota Supra Turbo
    92 Toyota Supra Turbo
    92 Toyota Celica Alltrac
    90 Toyota celica Alltrac
  6. #6
    Supramania Regular
    Join Date
    Nov 2006
    Location
    Georgia
    Posts
    740
    the ones i have circled are the ones you need from E10A. there are only 9 of them. the other plugs, E9... not much modification. it just goes to various engine components. the big block plug you need a few wires from. such as for the starter.
  7. #7
    2x88+2x89+1x91+2x92=ME
    Join Date
    Apr 2005
    Location
    Hayward , Ca
    Posts
    3,145
    Great information above. Here is a very good thread also that Tissimo mentioned.
    http://www.supramania.com/forums/sho...ht=wiring+peer
    I am on my second swap - this time its a 1.5 but I am using a 2jzzgte aristo harness.
    Here is a tip but more for someone who has doen it once :
    I did not have to extend much of the wires on the harness but I did one before so this time taking shortcuts. I have also removed all TRAC and Automatic and turbo/wastegate related VSV stuff from the harness. After removing everything not needed, and the wiring casing, I was able to have my wiring reach he stock location. The harness is pretting long once everything is open.
    I am not extending the wires near the ecu. I ma doing the extension closer to the plugs this time to keep the ecu area civilized.
    Only things I am extending are -
    - all the injectors, ( 12 wires )
    - the B/O wires for the Power to the Injectors and ignitors/coil packs. ( two wires ) ( connects to B1 plug of the 7m harness
    - H20, Oil , sensor wires for the gauge. ( M1 plug )
    After looking at the 7m wiring diagrams and the Aristo diagrams, the signals for power and sensors work in the same way. I am using the 7m Harness connectors ( B1 , M1 etc ) and splicing the corresponding power wires to make it plug and play.
    Also, I have the wiring colors mapped to the big square plug from the aristo harness . it has 50 something wires and most of them go to the Auto tranny/trac or Datalink connector.
    Only So far I have used the starter wire, hydrofan wires , and the w20 sensor and a couple more , that's it.
    I have a few more that I have forgotten about.
  8. #8
    Lurker
    Join Date
    Jan 2008
    Location
    Fort. Lauderdale
    Posts
    32
    I’m doing a swap in my 1st gen rx7. My setup is just an Aristo 2J Auto. All I would like to do is connect the ignition, Alternator, Fuel pump relays etc.
    What wires from the harness do I need to connect to get this thing going? All of my gages are Autometer mechanical so I don`t have to wire anything back to the dash.
    I’m not to savvy when it comes to the electrical aspects, so any help is greatly appreciated.
    If anyone is local, Fort. Lauderdale you can give me a call. 561 716 2678
    Thanks,
    Andre
  9. #9
    Lurker
    Join Date
    Jan 2008
    Location
    Fort. Lauderdale
    Posts
    32
    Tell me if I have this correct. Wires coming out from the E10 Connector:
    Pin 1 - connects to ignition switch
    Pin 6 - Malfunction Light (check engine)
    Pin 7 - Park/Neutral Safety Switch
    Pin 15 - ELS Defogger Relay - ?
    Pin 24 - M-rel EFI Main Relay
    Pin 31 - +B (1st click of ignition switch, accessory) EFI Main Relay
    Pin 32 -+B1 (2nd click of ignition accessory - on position) EFI Main Relay
    Pin 33 BATT (12.5 volts Constant)
    Pin 34 A/C amplifier ( is this for the fast idle cam when A/C is on,?)
    What wire is for the oil pressure and water temp gage?
    Is this correct?
  10. #10
    Supramania Regular
    Join Date
    Nov 2006
    Location
    Georgia
    Posts
    740
    the oil sensor wire comes from the big block and goes to the little connecter under the dash. you have to put the 7M plug on the end where it connects to the sensor as well as replace the 2jz unit with the 7M one. the water temp wire should also be on the big block plug
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
