Powered by Team Mondor
Page 22 of 22 FirstFirst ... 121819202122
Results 211 to 220 of 220
Thread: 2JZGTE MKIII Swap Info
  1. #211
    Supramania Regular
    Join Date
    Feb 2012
    Location
    Houston, TX
    Posts
    2,598
    Default Re: 2JZGTE MKIII Swap Info
    After lots of research it seems that wiring up a 2jzge vvti to a 7mgte mk3 is hell, would it be better to just get a 2jzgte or all you do is send off the 2jzge and 7mgte wiring harnesses to get modified?
  2. #212
    boostaholic
    MA717MGTE's Avatar
    Join Date
    Apr 2005
    Location
    Bristol VA
    Posts
    404
    Quote Originally Posted by Doat View Post
    dosnt matter have Dr. Tweek make a whole new harnesses, or marry the two together.
    same as above.
    00 Tundra 4x4 access cab daily driver
    87 Turbo 5 speed, Targa shell for sale
    RIP 82,83,86,86,87T,87,89,91 sold 82,88
  3. #213
    Supramania Regular
    Join Date
    Feb 2012
    Location
    Houston, TX
    Posts
    2,598
    Thanks for the info, will be doing that for sure lol.
  4. #214
    Lurker
    Join Date
    Nov 2012
    Location
    Delaware
    Posts
    17
    I have a question. I have an 87 supra non-turbo. Is it true that I cant swap it for a 2jz because of the engine were different for my year?
  5. #215
    Supramania Regular
    Kristian_Wraae's Avatar
    Join Date
    May 2007
    Location
    Aarhus
    Posts
    699
    No problem. You just need some special motor mounts or you can change the front cross member.
    http://www.bicperformance.com/products.htm
  6. #216
    Lurker
    Join Date
    Jul 2013
    Location
    North Carolina
    Posts
    is this two a twin or single turbo?
  7. #217
    Lurker
    Join Date
    Jul 2013
    Location
    North Carolina
    Posts
    is this to a twin or single turbo?
  8. #218
    Enjoyin' mah ride...
    Drake69's Avatar
    Join Date
    Aug 2009
    Location
    Richmond, Virginia, United States
    Posts
    669
    If it's a twin then you'd have to hammer back the firewall several inches to make the setup fit. Single wouldn't be a problem.
  9. #219
    Lurker
    Join Date
    Sep 2012
    Location
    Pa
    Posts
    12
    Hi I need help with my wireing harness and no one seems to Be able to help me and I don't want to spend $1400 on a new wireing harness,
    I have a 90 supra 7mgte r154 car and put a 2jzgte vvti aristo motor in, I've bin messing with this for a year, I need to know what gets hooked up where on the harness to make the car drivable, pleasee help
  10. #220
    Junior Member
    Roger UK's Avatar
    Join Date
    Jun 2010
    Location
    Newcastle
    Posts
    66
    Haven't read every single post in this thread, but just a couple of comments . . .
    It's certainly much easier if you get a 2JZ engine (and ECU) from a Mk4 Supra, along with all the ancillaries
    The Mk3 Temperature Gauge sender fits in the 2JZ block - I swapped mine so I knew the gauge would read correctly
    Photos HERE
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
