Powered by Team Mondor
Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Map Sensor
  1. #1
    Supramania Regular
    Join Date
    Aug 2005
    Location
    Columbia, S.C>
    Posts
    628
    Default Map Sensor
    Im looking a little more into a map sensor for my swap. Right the two options im concidering are the HKS (Denso) boost pressure sensor (i believe its the elusive 3 bar sensor) or a MR2 sensor and BCC. The HKS unit is 125 and i can get the mr2 and bcc for 90. any suggestions.
    Mods:
    HP:???
    TQ:???
    Coming Soon:
    Master Power T-70 1jzgte
  2. #2
    Peace!
    viperkillertt's Avatar
    Join Date
    Apr 2007
    Location
    Spokane, Washington, United States
    Posts
    893
    Default Re: Map Sensor
    Both prices are pretty good. I personally would probably go with the HKS, but that is because i dont know much about using the mr2 sensor.
    1989: 1jz 300RWHP/298RWTQ 14.7psi __________ My Supramania 1JZ build thread __________ 1986.5 N/A, 5 speed
    My Company: Diesel Power Products.com
    Bikes: 2007 Kawasaki Ninja ZX-14 & 1998 Honda SuperHawk/VTR1000
  3. #3
    Supramania Regular
    Join Date
    Aug 2005
    Location
    Columbia, S.C>
    Posts
    628
    the mr2 sensor doesnt read as much boost as the 1jz's but the boost cut controller would take car of that. On the other hand the hks sensor will read 2.5 bars of pressure but im not sure if the 1jz ecu can compensate for that high of PSI resulting in fuel cut from the ecu being able to read stock limits only and having to get a BCC any way. I want to go the HKS route but if I have to get a BCC id go with the MR2. Oh the MR2 sensor has been confirmed to work by pheonix tuning. The work close with Dr. Tweak and got my wiring harness extended for me. I believe the pheonix tuning owner is run by MR2 Guru (he really knows his ish), dont quote me on that though.
    Mods:
    HP:???
    TQ:???
    Coming Soon:
  4. #4
    Regular Member
    Join Date
    May 2007
    Location
    Charleston, SC
    Posts
    279
    Hey, thanks for the plug. Actually the MR2 Guru guy has a business called Phoenix Motorsports and his name is Josh. My business is Phoenix Tuning and, unfortunately, my name is also Josh, so it gets a little confusing sometimes. Add to the fact that I do wiring work for Josh at Phoenix MOTORSPORTS and it gets really out of hand...
    -Doc
    -Dr Tweak, Toyota engine swap wiring expert extraordinaire
    http://www.tweakdperformance.com/
  5. #5
    Boosted member
    annoyingrob's Avatar
    Join Date
    Jul 2006
    Location
    Calgary, Alberta, Canada
    Posts
    2,304
    Quote Originally Posted by Cya
    HKS (Denso) boost pressure sensor (i believe its the elusive 3 bar sensor).The HKS unit is 125.
    Yes, the HKS MAP sensor IS the elusive Denso 3bar sensor. Denso part 949940-6420 if you were curious. If you can get them for $125, I would highly suggest doing that, provided you have some way to scale fuel back 30% or so. This is also the same sensor as the APEXi 3bar.
    Quote Originally Posted by viperkillertt
    Both prices are pretty good. I personally would probably go with the denso, but that is because i dont know much about using the mr2 sensor.
    They're both Denso sensors
    It's a 3bar sensor, so wouldn't it read 2bar of pressure
    You wouldn't happen to have the part number for that MR2 sensor would you?
    My E-Penis is bigger than yours
  6. #6
    Supramania Regular
    Join Date
    Aug 2005
    Location
    Columbia, S.C>
    Posts
    628
    Quote Originally Posted by Dr Tweak
    -Doc
    OH! That explains alot. Eitherway, you did a good job on the harness.
    Mods:
    HP:???
    TQ:???
    Coming Soon:
  7. #7
    Supramania Regular
    Join Date
    Aug 2005
    Location
    Columbia, S.C>
    Posts
    628
    Quote Originally Posted by annoyingrob
    I have an afpr so that should help with the scaling, im glad someone has confirmed the HKS unit.
    HKS BPS:http://www.hksusa.com/products/?id=2006&rsku=0
    As for the MR2 sensor I don't have the part number but call Pheonix Motorsports:http://www.phoenixmotorsportsonline.com/
    They may have some sensors around the shop.
    Mods:
    HP:???
    TQ:???
    Coming Soon:
  8. #8
    Supramania Regular
    aphxero's Avatar
    Join Date
    Jul 2006
    Location
    Seattle, WA
    Posts
    787
    FWIW 4agze map sensor works too
    Part of:
    1989 Toyota Cressida... 1.5jz
  9. #9
    一番 King
    Dylan JZ's Avatar
    Join Date
    Oct 2007
    Location
    湾岸せん
    Posts
    2,222
    Actually, Rob the sensors are different from what I've seen.. BOTH are indeed 3Bar, however different part numbers.
    Enjoy following car culture? 'Like' our FB page: HASHIRIYA.net
    or check out our website: HASHIRIYA.net
    Advanced Race Technology / The Boost Lab
    JZA70 Aero GT / BW S360(83-75) / Zoonwen mani / HKS rail / Aeromotive / EV1000s / Tial 50 & v44 / BC 272s / Racepak IQ3 / AEMv2 powered
    7M FREE Zone
    Quote Originally Posted by suprahero View Post
    Chris, that isn't glare from the HID's. Everytime a 7m makes it through WOT without blowing up, God sacrifices a star and throws it towards earth.
    Quote Originally Posted by csnow View Post
    When all else fails, follow the manufacturer. What did Toyota do? Did they stay with the 7M? See, that was easy.
  10. #10
    Supramania Regular
    Join Date
    Aug 2005
    Location
    Columbia, S.C>
    Posts
    628
    So, do you know if it will work?(HKS)
    Mods:
    HP:???
    TQ:???
    Coming Soon:
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
